Habe eine Antenne im Haifischflossen Design abzugeben. Ist natürlich original Opel. 40€ inklusive Versand! Abgabe möglich ab Mitte Juni.
Haifischflosse
Can it be replaced easy? Does it have the same radio strength?
I believe that on Navi 900 the radio antenna is integrated in the left side rear fixed window, and replacing a long antenna with shark fin will lower the radio signalI would like also to change the antenna that is standard for InteliLink R 4.0.
On my Astra G , the long antenna was stolen after one month
Its easy. Just remove the C pillar trim, detach a little the headliner and its done. But I have no idea if the shark fin can fit with the normal antenna cable...
Haben Sie sie noch?
