Dashboard vents trim
  • Hello.
    I will write this in english as best i can. German or english is not my language.
    I need help with my astra.
    I have problem with trim on dashboard. On left (drivers ) side it does not stay in place. I take whole trim out and tried again. But it just wont stay in place. I even tried replacement part but its the same.
    Only problem is on the left side.
    Am i doing it wrong? Which side goes in first? Front i guess. Then you just press down side facing towards driver right?
    How to solve this?
  • I'm not sure, but I think you have to first insert the part (your arrow) into the guide and then clip it into the back.
    200.000 km im September 2024 erreicht.
  • Hi, i think there is a damage at the dashboard-side from the removal. Why did you removed the vents trim?
    .:::Andi:::.
    Einmal editiert, zuletzt von SmarANDI ()
  • Really? :(
    What sort of damage? Broken?
    So no fix until whole dash comes out?
    I removed trim because of rattles. Whole car rattles. Every part of interior. One day nothing. Next day like is falling apart.
    Thank you. I will try to post more pictures.
  • Please check the holding noses at the dash, if they are in the normal position. Maybe there is a part curved down or upside. Many removals are not good for every clip. Same problem like doorpanels...
    Pictures always helps
    .:::Andi:::.
