P2599 fault code
  • Hello guys ,
    yesterday i had installed on my car the gasket for chain tensioner as a preventative measure for my car which is astra k 1.6 cdti 2017 with 114k.
    After some klm on highway fault code P2599 came on the dash and it gets in lip mode.
    Are you recon there is something to do with the installation of the gasket ?maybe some bad connector or some pressure looses from some place ?
    by the way do you have an idea what exactly this fault means ???
    Thanks in advance
  • As far as I can see this trouble code is specific to the electronic actuator. If the actuator works when visually inspected, check the live data. Maybe there is an internal fault of the electronic.
