Beiträge von oastra
    Hi !
    What do you think about kind of by-pass (ableitung) to avoid tinker with the original cable loom ?
    I mean using a male+femal connector to take the "+" signal.
    The same kind of by-pass used to install the PowerFlex bar...
    Where can I found both male and femal connectors to build this by-pass ?
    From DT4/E32 pdf, the mal connector seems to be Delphi 12176836
    When you need to cut the optical fiber, just cut exact half of it, or each part need to be shorter to fit the Astra K ?
    Regards
    French User (and admin of french community about all Astra)
