Beiträge von mondy
    Using canbus ready leds for interior is a bad idea. They have a built in resistor . Simplified, if you replace 5w bulb with a 1w led it has a resistor to simulate 4w energy consumption in order check control doesnt recognize a bulb as faulty. That 4w goes to heat, so these led run very hot. For interior i recommend cob type or cree leds without a canbus resistors.
    Sorry for my english, but i'm not fluent in german enough to write in it.
    Well what opel is doing is actually a scam. Reviwers are promoting cars that in person are not as good. Someone said 99% of the people wont notice the difference. Well he's wrong. The biggest difference watts links has over standard one, beside improved handling, is that it can use soft bushings, meaning less road noise and less vibrations. That is the reason the astra in my16.5 lost beside watts link also sound insulation. So that extra engine noise would partially camouflage additional road noise coming from the suspension. Overall worse handling and more noise inside. Opel is actually scamming people into thinking they are buying better cars than in reality.
    Only until journalists get to review the 1.4 turbo benziner and 1.6 136 diesel cars. Then the same as 5 door astra, f*ck you no more watts link for you.
    And no you cant upgrade to watts link if you dont have it. The axle is not the same. You would have to change entire axle, including mounts.
